Bent and fitted the right hand corner former, P01-13.
Fitted the lower front baffle, P01-14. I needed to fabricate some filler parts on the right and left rear corners. The plans show where material is lacking. I increased the size of the filler parts to fit my circumstance, and also added bending tabs to the filler parts that tuck in between the cylinder and super-tin, similar to how the other tabs are fitted. Had to enlarge the hole for the dip stick so the outer diameter of the stick would fit through. The hole beside the dip stick was pre-cut on the supplied part, so I'll have to fill that in some way.
Flush riveted the left and right fence baffles to the fence brackets.
Next step is to secure all the baffles to their adjoining parts with sheet metal screws. When that is done, then the dredded step of trimming the baffles within 1/2" of the cowling.
P01-13 right front corner. Filler riveted on right rear of P01-14
